3400 with 260whp
    replied
    I disagree on both of your statements. Increasing velocity is possible (and is what I do) from porting. Yes, I remove about 1.5cc from the intake port, but the flow increase means higher velocity in the areas I didn't touch. You can shape a port to streamline the path of flow and the motor will see a smaller port. On 3400 heads, i increase flow substantially from the combustion chamber work. That changes the rate of flow without changing the port volume.
    You don't need more compression to see gains from more cam than 206/260 duration. You have to advance it to keep your bottom end happy but if you want more mid/top end at the cost of bottom end, you can keep your 9-9.6:1 compression.
  • EspanolaGuitarista
    replied
    Well...
    ....I understand your point of view Sappy, but you can't change the rate of flow without changing the port volume. Now that I recall changing the rate of flow at mid to high valve lift does make a difference, because of valve shrouding .25 of total diameter. The intake to exhaust ratio was biased about 78 percent or so. Getting that number down required me to run 2 degrees less duration on the exhuast side. So it was actaully 206/204 or 206/206 with .05 less lift on the exhuast for good balance. That may not work in the real world though. I was thinking 206/206 for the sake of an easy grind that would lower the ratio slightly. The larger the duration the more the ratio seems to come down. Anyways, if your thinking aboout running more than 206 degrees or 260 cam, you need more compression or your just wasting your time, in my opinion. You also need the 65 mm TB. The older TB won't cut it.
    replied
    Porting the 3400 heads for more flow without making a lot more volume is not only possible, but also makes quite a difference in simulations. Exhaust primaries are sized based on power output, not the size of the ports. 1.5" is too small for anything more than a mild build up 3400.
  • Mars
    replied
    Originally posted by MY91GT(Z) View Post
    im sure no 1a runnin 3.4 dohc cam in a j or l body that i ve seen or heard bout
    I've seen one in a third gen J. It's a nice looking show car, with some wild paint yellow, to red-purple, blue colour changing kinda paint if I remember correrctly...., everything on the engine is polished.
    I can't find the pics now, but they are someplace. Doubt it was ever raced or anything.
    replied
    Before I had my computer stolen...
    ...I did a full work-up on the 3400. I got everything nearly identical to the 3400 specs. A 206/206@.050 cam will work great. Don't bother porting the heads, they need flow not volume. Porting in my opinion won't change those numbers enough to make a difference. Make some shorty headers with 1.5 inch primaries inside diameter. a suggested length is 31 inches and does make a noticeable difference in simulation, but that isn't practical. Some think larger primaries make more power, but when you go from a small port to larger primary the gas expands and slows down. I would think square tubing to cover the D shaped port would be the best but that may also be impractical. 65 mm throttle body and blocking off the heat crossover got me about 225 horspower in the sim. That's a good 40 hp over stock.
  • MY91GT(Z)
    replied
  • vega
    replied
    ok well point made- as i said earlier- i am going to stick with a 3400. i actually just found one for a 100 bucks out of a wreck a 2001 grand am.
    do you have any pictures of what you are planning on doing with your intake or what you are going to do with the mounts to gook it up or a clue to any of that peguine?
    replied
    'nuff said
    replied
    replied
    The most efficient way is to turbo your 3.1, in terms of money. For longevity, I would go with a 3400 and turbo that. To do it NA, is possible and should be passed this year. If dave doesn't, eric hopefully will. High compression is a must if you want to keep it NA, but the good news is that 11.5-12:1 is safe. I want to know if 13:1 is safe
    replied
    You have to get permission? Chris has already posted pictures on here before, in the swap area. Do a search and I'm sure it will come up.
    Didn't know that.. i found them after browsing his 3500 pictures.. haha
    replied
    replied
    I'll post up some pics later on of a 3.4 DOHC in a 2nd gen. I have to get permission first though...
    It really dosen't fit very well.
  • Alxsmt
    replied
    the DOHC 3.4 wont fit in a Jbody without cuttin the firewall i believe
    my goal with my 3400 setup is 250whp, all i know is i *should* be somewhere around there, with my luck i will be under lol
  • vega
    replied
    Well at this point either way i am going to go with a 2000 up 3400. So i am going to go ahead and do the swap. I would like to basically do what you are doing with your supercharger- but actually using the moates.net system the ostrich i can use whatever injectors i want with keeping my harness and computer with out messing with it. and i can technically use my old injectors until i can tune it with the original injectors on the 3400. So i think i will switch injectors when i get a supercharger setup. But i have never made my own intake. if you have any designs that i might be able to look at so i can make it for my setup that i will be doing within the next month or to i wold be very grateful.
    i also would like to loose my ps and ac just as you do. its pointless in a light car. i also used to have a fiero. but i am curious i am going to use a 3400 not a 3.4 from a f-body like i assume you are using because the motor mounts are the same you just have to relocate the starter if i remember correct. how much different is that 3.4 than the one i am going to use as far as the intake goes?
