just took my engine block to the local shop.
I will have them shave 2.2mm(.0866")from the decks.
and later on there will be 0.8mm(.0314") taken from the heads.
this should result in a quench of .077"
and a CR of 8.43:1.
maybe I'll even shave .04" of the heads.
that would take me to a quench of .07"
and a CR of 8.57:1.
the machinist stated that the block should take the .0866"without trouble.
since the threadholes are casted way down in the block and are only somewhat atached sideways.(these are the pulling forces).
the forces on the cilindersleeves/bores are pressure forces..so that wouldn't change much.
we'll see...
sideways
building destroked 3400
maybe you can do that.
but those type of gaskets are ussually layers that are riveted together
one way or the other.
so one should seperate and clean each layer.
I would buy new ones for sure.
just my 2 cts.
IIRC I'm pretty sure you can buy that sealant to reapply it as necessary.
http://www.scegaskets.com/products/titan.html They are the ones with the sealant I speak of.Last edited by 1988GTU; 09-17-2007, 01:13 AM.
I wouldn't re-use them.
the sealing between the layers will be gone.
to the shop
tomorrow I'm gonna take the block
to my machinist for machining the decks
and have hin put a sleeve in cylindr nr.5
(where UNFORTUNATLY the pistonpin got stuck)
and if I have some sparetime this week...
I'll flow my other head and replace the valvespring
with the ls6 ones.
I'm also leaning towards using the mls headgaskets from the shop here.
they will probably do a better job sealing the heads than
the severe duty fellpro gaskets.
Gotta check my budget
sure ...according to the GM manual.
but I think that's only cause of the fitment issue of the intake.
I think the heads can take more than .020
iirc .020" is max for the heads.. any more than that is really risky
well isaac,
it looks like the heads would take .05 max or so without warping I guess.
I'm not so sure on the block though...but it's iron and no aloy...
Will that work or is that too much for the heads? What about the intake manifold lineing up? Sounds like a head ache!
in order to get a CR of 8.6 I will need to:
have the block and heads shaved .105 in total.
I checked the threadholes in the block for depth so the headbolts
will still fit properly.
.100 on the block itself is not wise so I will have about .037 shaved from the heads and about .068 from the block itself.
arias has the pins I need for those forged puppy's
they are 19$ a piece.
think I'll go with that.
BTW you can watch all pics on my build on photobucket
under futurefiero.
I now have to decide wether to go with a 3400-3.1 crank or with 6"rods.
You're right about that.
I planned on using the ford cosworth pistons that I had.
that would work fine with that 2.8L crank.
BUTT....since I bought these puppy's for some few $$$
I changed my mind and wanna go the 3400 way.
I am talking to a guy from arias to find out more on those
pistons and they seemed to be made for NA using 200hp nitrous.
according to beeri(arias contact) the pinn's are to thin on wallthickness.
however the upper part(above the top ring)is beefier than a standard piston
so I plan on removing some material there to get towards 9:1 compression.
we'll see if I can get some pinns from arias or elsewhere.
info on this would be apreciated !!
Bjorn
No, I was asking about the portsOriginally posted by bjornmk1 View Posthey forced firebird.
I misunderstood your question about the gasket.
the brown circle you see is from the factory gasket.
the engine had only 18 miles on it when it had a wrist pinn stuck....
Maybe I'm a little lost, but if you are using a 2.8 crank and 3400 pistons, wouldn't the pistons be really far down in the bore if you used 5.7" rods? The 2.8 had the wristpin location .3" lower in the piston so the same rods could be used in the 3.1 and 2.8 with a longer stroke. This would mean you needed 6" rods to get the piston back at the top of the bore at TDC.
