Well I just picked up a set of Envoy injectors from ebay... 100 for the set of 6, appear to be brand new.
Question is, I see they are rated at 28.1lb/hr but witch hunter rates them at 245cc @ 3 bar which works out to 23lb/hr at 43.5 psi... and if I use their calculator, bumping the pressure to 55psi only nets me 26.1lb/hr.
Now the question is, are these rated at 28.1 at 55psi? Or is it higher. I have to double check but worse case I can try to run the regulator from the rail that I got just to see the pressure and then put my adjustable unit back on and adjust accordingly.
This is the injector I have
GM # 25313185 AC/Delco # 12569573
