I cant seem to pm, it redirects me to the login page...that being said i have questions about your 4.3 throttle body modification...
I have the throttle body coming to me, but it will be a week or so before it gets here. I will be using it on a 3.4 in a fiero. I have the trueleo package, crane 272, heavy port n polish, 22lb injectors...and so on. I need the bigger tb.
I want to know what you did for the IAC and TPS. Since i dont have the tb here i cant see what it uses or has on it. I beilive i have the same style tps and iac as you on your 3400/3500 hybrid. the only difference is im obd1. i belive the tps and iac are the same from my 87 fiero, in that the tps reads 0-5v and the iac is the 4 pin, pintle valve type. does the 4.3 tb have the iac on it like other 60*v6 tb's? when mounted, which side of the engine is the throttle cable linkage on, cyl 2,4,6 or 1,3,5?
any pics or info would help. BTW i saw your initial post on the 4.3 tb, but it wasnt ever updated about the iac... just curious as to how you got it working and if it was working well.
thanks!
thanks!
