Does anyone know where or could they provide me the pin out of the 2000 grand am 3400 motor. i bought a clipped pcm harness for the 3400 for cheap. i'm trying to use the haynes manuel but there are more wires on the manual then on the pcm harness. thanks
need pinout for 3400 grand am
Powertrain Control Module (PCM) Connector C1
Connector Part Information
1219111
80-Way F Micro-Pack
100 W Series, Sealed (BLU)
Pin
Wire Color
Circuit No.
Function
1
WHT/BLK
2762
Transmission Fluid Temperature (TFT) Sensor Ground
2-3
Not Used
4
LT GRN
1222
1-2 Shift Solenoid Valve
5
DK BLU
473
High Speed Fans Control
6
DK GRN
335
Low Speed Fans Control
7
BRN/WHT
633
CMP Sensor Signal
8
PPL/WHT
430
3X Reference High
9
LT BLU/BLK
647
24X CKP Signal
10
BRN
2704
MAP Sensor 5 Volt Reference A
11-12
Not Used
13
ORN/ BLK
469
MAP/ECT Sensor Ground
14-15
Not Used
16
BLK/WHT
451
PCM Ground
17
BLK
2760
IAT Sensor Ground
18
Not Used
19
PPL
1500
Ignition Wake Up
Ignition Positive Voltage (Hot in Run/Accy/Start)
20
ORN
480
Battery Positive Voltage
21
Not Used
22
PNK
1224
Trans Fluid Pressure Switch A
23
Not Used
24
Not Used
25-27
Not Used
28
TAN/WHT
1669
HO2S 2 Low
29
TAN
413
HO2S 1 Low
30
PPL
420
TCC Brake Switch Input
31
BLK
2753
EGR Pintle Position Sensor Ground
32
GRY
435
EGR Valve Control
33
DK BLU
496
Knock Sensor (KS) Signal
34-37
Not Used
38
LT GRN/WHT
1749
IAC Valve B High
39-42
Not Used
43
BLK
1744
Fuel Injector #1 Control
44
YEL/BLK
1223
2-3 Shift Solenoid Valve
45
PNK/BLK
429
AIR Valve Control (w/California Emmissions)
46
PNK/BLK
1746
Fuel Injector #3 Control
47
LT GRN/BLK
1745
Fuel Injector #2 Control
48
RED/BLK
453
3X Reference Low
49-52
Not Used
53
TAN/BLK
424
Bypass Control
54
WHT
423
Ignition Control (IC)
55
DK GRN/WHT
817
Vehicle Speed Signal Output
56
BLK/WHT
451
PCM Ground
57
BLK/WHT
451
PCM Ground
58
PPL
1807
Class ll
59
Not Used
60
BLK/WHT
451
PCM Ground
61
BLK
2752
TP Sensor Ground
62
DK BLU/WHT
1231
Automatic Transaxle Input Shaft Speed (A/T ISS) Low
63
RED/BLK
1230
Automatic Transaxle Input Shaft Speed (A/T ISS) High
64
YEL
400
VSS High
65
PPL
401
VSS Low
66-67
Not Used
68
YEL
772
Transaxle Range Switch B
69
YEL
492
MAF Sensor Signal
70-71
Not Used
72
DK GRN
83
Cruise Disable/Inhibit Control
73
BLK/WHT
845
Fuel Injector #5 Control
74-75
Not Used
76
DK GRN/WHT
428
EVAP Purge Valve Control
77-78
Not Used
79
YEL/BLK
846
Fuel Injector #6 Control
80
BLK
2751
AC Pressure Sensor Ground
Powertrain Control Module (PCM) Connector C2
12191111
80-Way F Micro-Pack
100 W Series, Sealed (CLR)
Pin
Wire Color
Circuit No.
Function
1
Not Used
2
WHT
1310
EVAP Vent Solenoid Valve Control
3
DK GRN/WHT
465
Fuel Pump Relay Control
4
RED
1676
EGR Valve Ignition Positive Voltage
5
BRN/WHT
419
MIL Control
6
Not Used
7
LT BLU/WHT
1747
IAC Valve A High
8-9
Not Used
10
PPL
412
HO2S 1 Signal
11
PPL/WHT
1668
HO2S 2 Signal
12-15
Not Used
16
WHT
776
Transaxle Range Switch P
17
RED
1226
Trans Fluid Pressure Switch C
18
BLK/WHT
771
Transaxle Range Switch A
19
TAN/BLK
231
Engine Oil Pressure Switch Input
20-22
Not Used
23
Not Used
24
PNK
239
Ignition Positive Voltage (Hot in Run/Bulb Test/Start)
25
LT GRN
432
MAP Sensor Signal
26
YEL
410
ECT Sensor Signal
27
RED/BLK
380
A/C Pressure Sensor Signal
28
BRN
1456
EGR Pintle Position Signal
29
GRY
23
Generator F Terminal Monitor
30
BRN/WHT
2702
EGR Valve 5 Volt Reference A
31
Not Used
32
GRY
2709
FTP Sensor 5 Volt Reference A
33
GRY/BLK
2701
34
GRY
2700
A/C Pressure Sensor 5 Volt Reference B
35
BLK
2759
FTP/Fuel Level Sensor Ground
36-38
Not Used
39
DK GRN/WHT
459
A/C Compressor Relay Control
40-41
Not Used
42
LT BLU/BLK
844
Fuel Injector #4 Control
43
Not Used
44
LT BLU/BLK
1748
IAC Valve A Low
45
RED/BLK
1228
Pressure Control Solenoid High
46
LT BLU/WHT
1229
Pressure Control Solenoid Low
47-48
Not Used
49
LT GRN/BLK
444
IAC Valve B Low
50
TAN
472
IAT Sensor Signal
51-54
Not Used
55
DK GRN
890
FTP Sensor Signal
56
GRY
773
Transaxle Range Switch C
57
DK BLU
1225
Trans Fluid Pressure Switch B
58
BRN
1174
Engine Oil Level Switch Input
59
LT BLU/BLK
396
Cruise Engaged Input
Cruise Status
60
Not Used
61
RED
225
Generator L Terminal Control
62
Not Used
63
YEL
657
64-65
Not Used
66
DK BLU
417
TP Sensor Signal
67
Not Used
68
YEL/BLK
1227
Transaxle Fluid Temperature (TFT) Sensor Signal
69
PPL
1589
Fuel Level Sensor Input
70
RED/WHT
812
24X CKP Sensor Battery Positive Voltage
71
Not Used
72
RED/WHT
812
CMP Sensor Battery Positive Voltage
73
BLK
407
CMP Sensor Ground
74
BLK
407
CKP Sensor Ground
75
BRN
436
AIR Relay Control (w/California Emmissions)
76
Not Used
77
Not Used
78
BRN
418
TCC PWM Solenoid Control
79-80
Not UsedColin
