Ive been thinking about this, but would like to get some of your opinions. I plan on going with a 3400 ( which I bought today ) with a 3500 top end swap ( more than likely from the store here ) probably the street p&p and maybe? mill the heads +.050 since Im loosing compression from the 3400 heads to the 3500 heads. Ill also be using a stage 1 cam from mms. Now Ill be keeping the stock 3100 fuel rails and injectors and this will be running off the 3100 ecm ( obd 1.5 ) so I wont have a way to tune for it.
question is, will I be running too lean from this? Right now Id rather not swap over to obd2. That might come later on down the road, but not right now. I know I cant use the 3400 rails and injectors cause then Id probably be running wayy to rich. Or will I just have to try it and see what happens when I run it?
opinions? Thanks!
opinions? Thanks!
