hi folks, i need some help here.
i'm doing an intake manifold swap on my 96 3100. i was lucky to have spare parts from another motor to help me with this conversion.
my original 96 was a roller rocker motor while the one i'm using isn't. no biggie. the heads have the slot for the roller rocker conversion.
my REAL problem is, i'm using the 2000 mailbu 3100 intake. everything is going well. i'd like to know how do you line up the lower intake manifold to the head, so that you can gasket match the lower intake manifold?!
i already preinstalled the gasket on the head, made my scribe marks on the head, and matched the head to the gasket, but how do you do the lower manifold to the gasket?
help is needed here. i don't want to cut off any unecessary metal, if i can avoid it....... thanks
