Hey guys,
Well, I have an 87 Fiero SE / V6. I'll be dropping in a 5-Speed manual (Getrag). I'm trying to decide what the proper build should be. Ideally, I'd really like to see high 14s in the quarter in my Fiero, but I would be satisfied with low 15s.
As I understand it, the 2.8 can be made to produce higher rpms (I think, correct me if I'm wrong, because of the longer stroke?), but of course, the 3.4 produces more torque obviously because it has more displacement.
The motor I have in there right now was kind of a hack job. I didn't know much about cars back then, so I rebuilt my 2.8 into a 3.1 using a "stroker kit" from ARI Racing. It dropped my compression to something like 8.5:1. I installed .030 overbore hyperutectic pistons which I assume upped the compression slightly, but still lower than the stock 8.9:1.
Now... when it comes to performance, I COULD just drop a 3800SC or a 4.9 in there, but I'm really a stock nut. To me, everything has to look 100% stock or original, so I'm sticking to the V6/60 GEN-1 block. Plus, I also really REALLY like the sound it produces. With all of that in mind though, I'm stuck having to live with the pretty red Fiero intake plenum, which as I understand it is pretty restrictive to anything over a stock HO 2.8.
I guess I'm looking for some advice. I want to know if I should try to build a high-revving 2.8, or build a beast 3.4 (or something in between). My goal is 200hp, wether that's at 7,000 rpms on the 2.8, or 5,500 rpms on the 3.4 doesn't really matter. I figure 200hp is reasonable for a built up 3.4 with the H272, and odds and ends.
With the restrictive intake that is the Fiero, what do you think my best solution would be?
Thanks!!!
Todd,
2006 Pontiac Solstice
2004 Volkswagen Beetle
2002 Ford Crown Victoria LX-P74
1987 Pontiac Fiero SE / V6 5-Speed
1984 Porsche 944
1981 Pontiac Trans Am WS6
1973 Volkswagen Type-2 Transporter
Thanks!!!
Todd,
1984 Porsche 944
