I've been thinking about building a 3900 for my Fiero. I've heard that a 3500 uim will swap onto a 3900 lim, if this is true, which is better? I would also like to run a turbo in it, still have to done more research. Also any ideas on cam profiles,turbos ,compression ratios, and TBs.
Best UIM for a 3900
If you can't control the 3900 variable intake properly, then the 3500 intake is probably the best bet.
Did you see Joseph's turbo 3900 Fiero?sigpic
Yeah I don't know if it's PWM. If not a RPM switch would be the way to go defiantly.sigpic
