I need to know how to put a 3.1 computer in this car. The 2.8/th125 is coming out and i would like to tackle the computer layout while the engines being built. It's going to be turbocharged w/ MPFI computer.
[IMG]
[/IMG]
The first picture has 2 black plugs and a white square plug. The 2 black ones came from the computer and there are 2 black plugs that come from the center console that the White square plug came from. Picture 2 shows the center console plugs.
Does anyone know where i go from here? Is this for sensors and switched igntion, gauges, to the dash? I imagine i drop the whole harness in, hook up the constant power and splice certain pin # from back of 3.1 computer to everything else? gauges, switched ignition, fan relays, check engine light... i need help so we're just trying to absorb as much info as possible on the computer swap.
[IMG]
[/IMG]The first picture has 2 black plugs and a white square plug. The 2 black ones came from the computer and there are 2 black plugs that come from the center console that the White square plug came from. Picture 2 shows the center console plugs.
