Aw Crap!
    replied
    If you go to Napa they can get you 12 of them.. for a 1991 Cavalier 2.2L (Exhaust valve seals x12)
    Moonwell has put a ton of miles on his cammed 3400 w/o any seal problems.
    I did the same, but at Discount (I know, I know - but I haven't seen cheaper Felpro's anywhere), asked for 1991 2.2 Cavi seals. They were $13 or $15 for a set of 8 (4int/4exh), IIRC they came to $27 for both packs. I didn't mind getting extras since I have a bunch of heads that are going on various cars. 3 packs of seals is enough to do 2 set of heads .
  • zofo61
    replied
    Thanks Dave...and Forced....I appreciate the info
    replied
  • zofo61
    replied
    Cool......I am sold on the Cavi seals then if you say so Dave...and you as well...Force.....so all I need is a part # and I am all over ordering the seals and the shims. Have the Valves and the springs......starting to get all the puzzle peices together........Thanks
    replied
    They're better because.. they fit. the 318 seals don't fit the valve stem very tight and let oil past causing exhaust port sludge, excessive carbon buildup in the cyls and smokey startups.
    Mine popped off because the springs moved over and hit them, the ones that hadn't been pulled off were just fine.
    replied
    Originally posted by zofo61 View Post
    If they are better...I would love the #, but arnt the 2.2 seals the ones that SuperDave had issues with?. And can someone verify why they are better......might as well debate it before i buy it............Hmmm?
    Thanks guys.
    Dave has issues with them because he used the flat shims and the spring walked enought to het the seals.
    Part number in a few minutes, got to finish cooking for our family of 6
  • zofo61
    replied
    Thanks guys.
  • geldartb
    replied
    do these have a tighter seal on the valve stem.
    i think i remember someone saying something like that.
    replied
    I just want to confirm these #s before I order. I am doing the LS6 springs on 3500 heads and I need:
    LS6 Springs
    GM LS1/6 Shims GM # 12565118
    Chrysler 318 seals Fel-pro Viton # SS72844
    YES?
    Thanks
    People say the 2.2 seals are better. I bought a set(two actually-come in a box of , and they are the same seals as a couple of Chrysler and GM motors.
    I have the part number in the garage, I can grab it if you need.
  • geldartb
    replied
    LS6 Springs
    YES?
    Thanks
    yep your good to go . if you get stuck check out the link its pretty informitive on this subject. if you need any extra tidbits of info
  • zofo61
    replied
    LS6 Springs
    YES?
    Thanks
    replied
    np
    I've got a friends 3400 heads here that i need to do the same to..
  • johnnymossville
    replied
    Well Dave, thanks for the info. Now that I need to run valve seats instead of the brass shims I'm deffinitely going to buy the Comp Cams springs as I know the LS6 springs will bind with the lift of my cam. Good to find that out now. And thanks to geldartb for posting the link for the shim/seats.
  • geldartb
    replied
    either place is cool to order from. ive ordered from both and they ship fairly quick so your not waiting forever.
    i went with the info on this page from grandamgt.com i need to get off my ass and finish the engine so i an enjoy it.
    when i did mine i removed as little as possible and found a socket that fit over the nub thing the valve stem comes up through. i can say one thing theres no way there coming off the head.
    replied
    cool, thanks. $27 from there for 12. Now i gotta wait till i get paid, lol
