Will a V8 starter fit on the side of a RWD 2.8-3.4? I just got done putting a factory replacement on this damn 4x4 and having to remove almost the entire front end to get to it next time I wanna put a gear reduction one on it if theres one that fits.
starter question
I'm not sure about the V8 starter but I know a lot of guys are using the 3X00 starters cause they are bigger than the older ones.Mr_Efficiency
90 Grand prix - Lawn ornament
Black, 3.1, 5 speed
Future holds: Striped and then scrap yard
97 Cavalier - Stock car
Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
Future holds: Just more trophies :twisted:
New project on the way: 88 S10 reg cab, short box, 5 speed.
Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
their not bigger they smaller and lighter and give more power when starting for faster starts94 BerrettaZ26 3400,5 spd, aluminum flywheel, stg3+ spec clutch, poly mounts everywhere, strut and strut to rad braces, s&s headers, euro mirrors, and taillights, E36 headlights, blk widow spoiler, GTU rimz, intrax, KYB, OBD2 swap rear disk swap with ss lines and ss clutch line, addco rear bar
07 Chrysler 300 Base, with C frt bumper blk halo headlights and foglights. Coming soon tinted taillights and 22". The Family ride :)
Yeah but its on FWD which my blazer is not and I'm pretty sure FWD will not swap out to RWD so back to my question please. Does anybody know of a smaller gear reduction for a 2.8/3.4 or will a V8 starter work?87 3.4 4x4 blazer
have you checked a late model F body with a 3.4L, I think they stoped the 60 degree in 98 in the f body. They should have and smaller gear reduction starter and its a RWD set-up68 El camino 454 speed muncie 3.90 posi 12 bolt,
80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
60 Impala 2 door hardtop L79-327 T56 4.11 posi.
83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
91 Z34 now has a hm284. and belly pan in the works
The last 60V6 in an FBody was 95.[CENTER][color=red][b]-Brad-[/color][/b]
[size=2][b][color=blue]89 Mustang : Future 60V6 Power[/b][/color][/size]
[SIGPIC][/SIGPIC]
[size=2][color=blue]Follow the build -> [url]http://www.3x00swap.com/index.php?page=mustang-blog[/url][/color][/size][/CENTER]
I thought 98 is when they went to 3800 but anyways a 95 should still have a better starter68 El camino 454 speed muncie 3.90 posi 12 bolt,
Nope the Camaro starter is the same as the S-10. It was the same from the start to the end of production.
I don't think a V8 starter will work out of the box but it may be able to be modified to work. I don't think anyone has the answer for sure but you might want to go to the parts store and ask to see a stock 2.8L starter Vs A V8 starter. If they can interchange then you know a gear reduction starter will work.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Because... I am, [COLOR=darkblue]C[/COLOR][COLOR=darkred]A[/COLOR][COLOR=darkblue]N[/COLOR][COLOR=darkred]A[/COLOR][COLOR=darkblue]D[/COLOR][COLOR=darkred]I[/COLOR][COLOR=darkblue]A[/COLOR][COLOR=darkred]N[/COLOR]
well damn, just an idea.68 El camino 454 speed muncie 3.90 posi 12 bolt,
I know this is an old thread but since its mine blah.
I found this over at fullthrottle and it looks promising. If anybody cares
87 3.4 4x4 blazer
