ok so i need bigger injectors, found out my 3400 and 3500 injectors will be too small and they cant be modified like i was hoping.. whats my options? i need at least 30#
bigger injectors
some ppl r running trailblazer injectors if im not mistaken i think they 27-28lb injectors or else u could go w/ gtp injector at 36lb for like 160 on zzperformance.com for some brand new ones94 BerrettaZ26 3400,5 spd, aluminum flywheel, stg3+ spec clutch, poly mounts everywhere, strut and strut to rad braces, s&s headers, euro mirrors, and taillights, E36 headlights, blk widow spoiler, GTU rimz, intrax, KYB, OBD2 swap rear disk swap with ss lines and ss clutch line, addco rear bar
07 Chrysler 300 Base, with C frt bumper blk halo headlights and foglights. Coming soon tinted taillights and 22". The Family ride :)
FYI,Originally posted by MY91GT(Z) View Postsome ppl r running trailblazer injectors if im not mistaken i think they 27-28lb injectors or else u could go w/ gtp injector at 36lb for like 160 on zzperformance.com for some brand new ones
ZZP used to sell 36# injectors but not lately and they are not new. There used injectors that have been cleaned and flow balanced. Last time I checked, they were not listed on their site.[U]Your local OBDII moderator[/U]
2000 Grand Am GT w/ WOT parts
arnt the gtp injectors too tall for the 3400?
what year trailblazer?
EDIT: will these work?? http://www.jegs.com/i/Accel/110/1506...749691%7C10299
also could these be flow matched better that what it says they are? i dont know how close that means they areLast edited by Alxsmt; 03-13-2008, 01:34 PM.[SIGPIC][/SIGPIC]
[u][b]88 Beretta CL[/b][/u]- 13.641@102.76mph (rwd LS1/t56 conversion in progress)
[B][U]77 Celica GT[/U][/B]- 3400/3500 swap in progress (engine from the beretta)
Just the opposite, GTP injectors are too short. You'll need to grind off about 1/8" from the fuel rail bolt bosses or get the adapter plates from the WOT-TECH store.Originally posted by Alxsmt View Postarnt the gtp injectors too tall for the 3400?
For the trailblazer injectors you'll want any year with the inline 6 engine.
Those Accel injectors are flow matched pretty well, but I don't know if they will fit.[U]Your local OBDII moderator[/U]
hmmm, would it be possable to tune it so it wouldnt run rich cuzz those are a bit bigger than i need, im assuming it is (gonna get it tuned right after i get my engine in)[SIGPIC][/SIGPIC]
im going with s/c 3800 injectors. they are 36# at 60psi. about 32 at 45psi[COLOR="#B22222"]3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe[/COLOR] ALL FOR SALE (minus the car)
2012 Chevy Sonic Turbo 6spd
You can tune for large injectors, but if you don't need them then it's best to get close to what your motor will be using.[URL="http://isaachayes.60degreev6.com/"][SIGPIC][/SIGPIC][/URL][SIZE=1][COLOR="RoyalBlue"][/COLOR][URL="http://isaachayes.60degreev6.com/z26/ss-todo.htm"][IMG]http://isaachayes.60degreev6.com/z26/signature1.jpg[/IMG][/url] [COLOR="#FF4000"]New 2010 project (click image)[/COLOR]
[/SIZE] [SIZE=1]16.0 1/4 mile when stock. Now ???[/SIZE] [SIZE=1][U]
Original L82 Longblock[/U] with LA1, LX9, LX5 parts
[/SIZE]
i got 43 psi off my 3400 rail[COLOR="#B22222"]3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe[/COLOR] ALL FOR SALE (minus the car)
does any1 know what psi trailblazers injectors are rated at?
i found some for cheap and i THINK they will be enough for me. im hoping for 250whp im guessing that would be around 275fhp. but chances are it willl be only around 230whp or so. will those injectors be plenty????[SIGPIC][/SIGPIC]
Yes, 28lb/hr would be good.. you could also snag a set of 3.4 DOHC injectors and run them @ 55PSI for around 26lb/hr.Past Builds;
[url=http://www.v6z24.com/registry/SuperDave]1991 Z24, 3500/5 Spd. 275WHP/259WTQ 13.07@108 MPH[/url]
[url=http://www.v6z24.com/registry/superdave/5]1989 Camaro RS, ITB-3500/700R4. 263WHP/263WTQ 13.52@99.2 MPH[/url]
[url=http://www.v6z24.com/registry/superdave/6]1972 Nova 12.73@105.7 MPH[/url]
