i just picked up some 3400 intakes and got the fuel rail and injectors with them thinking that they'd be 21 lbs injectors.
i checked the numbers and found they are 18lbs. Now... I thought that my 1997 3100 came with 19 lbs injectors and the 3400 and 3100 large port had the 21 lbs injectors...
(i should mention my 3.4 intakes and injectors are out of a 97 venture van)
at work im doing the lower gaskets on a 98 olds sillouhette van with the 3400... so i looked at those injectors and sure enough... 18 lbs injectors... wtf is going on... i need some educating
