Are you going to heat treat them at all?
4 bolt mains
Don't need it on 4140Originally posted by Wiz85 View PostAre you going to heat treat them at all?
We just made a cable cutter at the CNC shop that was a casting (and kept breaking), so we made it out of 4142 (twice the tinsle strangth of a casting), the last 2 numbers is the C-scale via Rockwell and both 40 and 42 are VERY strong in raw form. I would be worried if treated that perhaps you could snap/chip a cap too easily with over torque on the bolts, or a mis-hap.
chivette_boy, I'm anxoiusly awaiting a price. We have machines that could easily make them within .0002", so get those on there and lets test 'em out!Last edited by ForcedFirebird; 04-30-2008, 08:59 PM.
Yeah I love any kind of 4130-40 steel, good stuff for the strength/weight ratio vs mild steel. I also like heat treating but now that I think about it, heat treating it after align-honed would make it out of spec. And heat treating before align-honing would pose a problem b/c the machine shop would probably have trouble cutting on the mains to align them up. I've seen broken carbide bits after people trying to machine heat treated 4130. So yeah I would take back my comment. Chrome-moly splayed 4-bolt caps would hold way longer than the block would.Eric
exactly the 4130 modified is a very workable and strong material. heat treating would make line honing and proper intallation impossible, and would make the brittle and suseptible to cracking under high load. that and there already over 4 times stronger than stock.Originally posted by Wiz85 View PostYeah I love any kind of 4130-40 steel, good stuff for the strength/weight ratio vs mild steel. I also like heat treating but now that I think about it, heat treating it after align-honed would make it out of spec. And heat treating before align-honing would pose a problem b/c the machine shop would probably have trouble cutting on the mains to align them up. I've seen broken carbide bits after people trying to machine heat treated 4130. So yeah I would take back my comment. Chrome-moly splayed 4-bolt caps would hold way longer than the block would.1982 Twin Turbo Chevette:
2007: 3.2 Twin turbo, 309rwhp, 378 rwtq (detuned, stock botom end) 12.97@110mph
2008: 3.5 TwinTurbo...stay tuned
Just to mellow my curiosity, how difficult is it to modify the block for the 4 bolt mains? Not that I would think the engine shop I plan on taking my engine to would have any trouble, I personally would just like to know what their going to have to go through.3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
drill two holes, fit she caps and line hone. first quote i got back was $600 labor plus Mat. for one pair it would be less if i were to make more but i would like to try them before first. so it looks like it wont be cost effective because i can buy 6+ blocks for that price, cheaper to run em till they blowOriginally posted by fieromadman View PostJust to mellow my curiosity, how difficult is it to modify the block for the 4 bolt mains? Not that I would think the engine shop I plan on taking my engine to would have any trouble, I personally would just like to know what their going to have to go through.1982 Twin Turbo Chevette:
$400/pr max for the first set and after that if i do a run of 30 ish sets ild like to see a price of $200/pr. not sure what this shop had for equip all i know its it would be don on a cnc mill1982 Twin Turbo Chevette:
I personally know a one off machine/prototype shop supervisor who has done many things very reasonably for me in the past. If you're willing send my your specs and etc and I'll see what he says. BTW, they got some badass equipment there!3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
What kind? I have a MoriSeiki lathe with dual terrets, and 12" chuck - capable of 20" diameter and 36" length, and a Kitamura MyCenter2 mill - and some various manual machines.Originally posted by fieromadman View PostI personally know a one off machine/prototype shop supervisor who has done many things very reasonably for me in the past. If you're willing send my your specs and etc and I'll see what he says. BTW, they got some badass equipment there!
That's why I asked
3.4L RWD head gasket(1994 camaro 3.4L):
3100 head gasket(2000 malibu 3.1L):
Looks like the 3100 gaskets are missing two holes on the outboard edge of the gaskets on either corner, when compared to the RWD 3.4L.
The 3400 (2003 Impala 3.4L) comes up with the same part number for the head gasket as the 3100.Last edited by TurboProject; 05-08-2008, 10:51 AM.Wayne
'94 3.4L V6 Camaro 5-spd
Custom TO4E-T3 Turbo/Intercooler Setup
Megasquirt Stand-alone EFI (www.megasquirt.info) controlling fuel and ignition timing
My Megasquirt 3.4L F-body Install Guide:
http://www.turbocamaroproject.com/me...tallGuide.html
the funny thing about GM is that they use pretty much whatever they have lying around when they build stuff. You can also use the 3.8L (1995+) F-body (camaro/firebird) bellhousing for a T-5 because it is identical to the 60* v6 bellhousing (yes i know its a 90* motor) and has the starter on the opposite side as the 3.4L RWD.
I know this because i bought a tranny/bellhousing to replace my worn out T5 just a little while ago from a 2000 3.8L Camaro. I have the bellhousing sitting in my "garage" rite now - along with my old tranny (might hav eto build it up
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club
