ok well a little explination first, the car has been running and idling on its own for a while now. ive been trying to datalog, but cant get a connection. so today i thought id do somethings to make the engine bay look better and take care of my exhaust. heres what i did today..
moved coil packs into trunk
moved the cts, tcc and reverse switch's wiring to under the exhaust.
put a new connection on the positive terminal (everything flickerd when i started the engine today)
ran new pipe from the collector to the tips.
when i got done with the exhaust i went to start the car and its started like normal, ran rich and then idles right at 950. then the lights on the dash went out and the car died. i went back and found the positive terminal was loose so i tightened it again and started the car. it died imediatly. i started it again, revved it up to clean off the plugs and took my foot off the gas...it died again. i checked the codes, 33 was the only code. thats for map sensor voltage high. i checked the map, vaccum and wiring. all was ok. reset the ecm and tried it again....same thing.
thinking it was a vacuum leak, i smoked the engine (leak detector from redline, good tool to have) and i found the throttle body adaptor was leaking. so i replaced the gaskets, added some rtv and waited about 45mins and started it again. same thing, died imediatly. i tried again this time holding the rpms around 1200, it surges like it has a vacuum leak. so i smoked it agian. no leaks. now im puzzled. i swapped map sensors...nada.
i pulled off the tb and adaptor, cleaned then up made new gaskets again, rtv again and let it sit for about an hr. still same exact thing. i smoked it again and took off the oil cap to see if there was anything coming from inside of the engine....nothing.
where do i go from here? i have no vacuum leaks, the wiring isnt grounded, map is good, and it ran fine before.
did the batt cable that came loose screw things up in the ecm? it did flicker and shut off while the car was running...
i dont think there is anyway me putting new exhaust on can affect the map....can it?
is there a way that the coilpack relocation cause this problem?
how can i test the map wiring ( its got the 5v reference, but i cant tell what its supposed to be, voltage wise, at teh other terminals. i know the other is ground.)
what frustrates me the most is the car ran fine into the shop, and i really didnt do anything that would cause a problem with the map. i cant get the damn aldl cables to work so im screwed there.
im really not liking the fiero today.
