well im still waiting on my aldl cable, so i dont have any ecm info to accompany the problem. no codes.
the last 3500 i had in here did the same thing, so i just adjusted the idle set screw and all was good, sort of. it idled high and would buck on me at different times, not a good fix.
the new 3500 has a new 4.3 70mm tb on it and i didnt adjust the set screw at all, the car will idle on its own till it comes up to temp, then it surges and eventually dies.
thinking it was related to the cts, i replaced it and the iac just to be sure. no changes.
if i barely hold my foot on the accelerator it will idle at 1100rpm and surge slightly, but as soon as i remove my foot it jumps up to about 1500rpm then down to below 500rpm and dies.
i tried reading posts every where about this problem, apparently the fiero had a big issue with this, but i dont even ahve the same ecm anymore, so i ruled that out.
some things that have happened to others i looked into, and couldnt find anything relivant. i had the batt checked and charged, alt is putting out 14.4v, coolant temp sensor ohms read right on the sensor and back at the ecm, the iac is working and i think its what the computer is using to surge the engine. im going to try a heated o2 on thurs and see if that helps.
Has anyone ever expierence anything like this? What was your fix
