Hey, i need help figuring out if this build will work... Its an early 80's 2.8 freshly rebuilt with flat top pistons, zero deck. I want to use a gen 3 3400 topend and was wondering if id have any valve clearance issues? I dont have the exact profile of the cam but i think its slightly smaller because its an early 80s motor.. Its actually my friends car and he says he has the profile of the cam if you guys need it. The point is , we want to raise compression and use the big port topend with a distributor for now and an external fuel regulator. what injectors can i use, do i have to use stock inj. with stock ecm? First things first, what do you guys think? If anyone has done something similar to this, let me know if its going to work out or what we need to do... im pretty sure he's not ready to do the 7730 swap so i need a quick temporary solution to all this... He just wants the car to run decently for now until the computer swap. thanks in advance
Fiero 3400/hybrid Help
yup. swap the whole 3400 in there. its easy and well documented on fiero.nl3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
2012 Chevy Sonic Turbo 6spd
almost done, it goes on monday to indiana so darth can tune it while im in great lakes. then its off to florida i go
ya, it screams3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
perfect? dont know about that, but it will run good.3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
