im putting togeather a 2.8 build, im going to use the camaro sfi intake, can i use aluminium heads with that intake, they will need to flow pretty good cause its gonna be t/c'd
aluminium head question
Nope, ports don't line up between the aluminum heads and iron-head manifolds.-Brad-
Go with 3400 heads and 3400 intakes. You'll thank us later
You'll need to convert to DIS and MPFI though.
Yes, heads and intake from a FWD. All you have to do is rotate the intake 180 degrees and you are all set.-Brad-
the FWD stuff far out-flows the RWD stuff, night and day difference.
True that, and a smaller better shaped combustion chamberOriginally posted by Superdave View Postthe FWD stuff far out-flows the RWD stuff, night and day difference.VIDEO Acadian http://videos.streetfire.net/video/8...7f00197eea.htm
Six-t-Six Motorsports
2.8L Chevette Roadcar
3.2L Acadian Racecar
