i wanted to know if replacing the intake on the 3.1 with the 3.4 intake will make more power will i have to switch heads too?
huge dessison maker
The 3400 intakes are large port and the '97 3100s are small port. Also, the 2000 and later 3400 upper intakes flow better than the earlier ones. Plus you could use the 3400 TB, although then you would need to free up your exhaust flow to take advantage of the increased intake flow. Engines are basically air pumps, which means if you put more air in (better intakes) you will put more air out.
Well I was talkin Iron head stuff which I see now is wrong since he has a 97 Lumina. So the post is about 3100 and 3400 intakes. But in any case the same rule applies.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Per his Vehicle Information dropdown, its a 97 Chevy Lumina with the 3100.-Brad-
Ah I forgot about that thing.Originally posted by bszopi View PostPer his Vehicle Information dropdown, its a 97 Chevy Lumina with the 3100.
As montess said above, you can swap a complete 3400 top end onto your 3100. From what I understand you do not have to swap the 3400 heads if you don't want to, but I believe the ports won't line up properly with the 3100 heads and it isn't optimal. The 3400 heads have larger ports, and an all around better cast.
I also believe if you switch to a 3.4DOHC from any year you are going to have to rewire the car because the Pushrod and DOHC motors are very different. If you are looking for performance, the DOHC is hard due to its lack of aftermarket.
An almost direct swap in would be a 3400 motor which will give you a better base, your other options are a 3400/3500 hybrid or a straight up 3500.
Dual Outlet Exhaust with Resonator Delete, Front STB, Rear STB, GMPP Trailing Arms
3400 and 3100 head ports are exactly the same, the valve is .02 larger but thats not enough to help/hurt something... It's the upper runners that are the biggest difference.
I do learn something new everydayOriginally posted by 3400-95-Modified View Post3400 and 3100 head ports are exactly the same, the valve is .02 larger but thats not enough to help/hurt something... It's the upper runners that are the biggest difference.
I dont know if you can bore a 3100 block to 3400 size, and also cam and valve work on a 3100 with 3400 top end will do more power than a 3400 alone.
