This past weekend I put a cam into my car since I started to get a lifter tick. The car runs fine and the idle is great but it feels like that there is no power at all, feels like its less than stock actually. I can punch it and the car doesn't even want to downshift and it goes nowhere quick. I set the timing to 12* and put some 89 octane in it. I don't think that the computer is too happy with the cam. The cam is basically a Comp 260H with a wider LSA. With the cam I also did a new timing chain, lifters, pushrods, Comp roller tip 1.6 rockers, springs and some lightly ported heads and intake. The car also has 3.1 injectors in it and the fuel pressure is bumped up a little. Before the car ran like a top and now its a little shaky, it runs great but has no power and I don't have much brakes at idle either. Let me know if there is anything that I can do that will give me the power that this cam should have, something is wrong.
Car is an 89 Camaro with a 2.8, it also has headers and full catback. I believe that everything is hooked up correctly.
Cam specs:
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 212
Duration at 050 inch Lift: 212 int./212 exh.
Advertised Intake Duration: 260
Advertised Exhaust Duration: 260
Advertised Duration: 260 int./260 exh.
Lobe Separation (degrees): 114
Cam specs:
