hey, i just got a 88 with a 2.8 and was thinking of some hop ups i saw the ported intake manifold after that what else is there to do to this engine thanks
88' celebrity
It all depends on how much money you are willing to spend..
Then i'd do either a full engine swap to a 3400 OR build a hybrid using the 3100/3400 heads on the 2.8. Toss in a H260-2 cam from Crane and a set of the "header" manifolds from a '04-05 Malibu (2 fronts). She'll scream then.
Of course you'll have to get into ECM tuning either way.
stock 3400 swap with the auto trans will put down about 150-160 to the wheels. With the hybrid i'd say about the same but it would make peak HP in the 6-6500 RPM range whereas the 3400 would be around 5500 RPM.
a 5 speed would be a nice upgrade with the stock 3400.. then you'd be just under 200 @ the wheels. and depending on how well you can drive and how heavy the car is that's a mid to high 14 sec 1/4 mile.
