Hello my name is Ryan,
im new to forums but im looking for advise.
im putting a 3.1 in my sand rail, i have a 1999 or 2000 engine pulled out of a buick centry first is that an ideal block to start with? second i will be installing the edelbrook carb intake.. so the stock alum. heads iron heads will be used.. as far as that goes my compression will be lowered do to the change.. so pistons?? which ones? are the rods and cranks the same?? as far as i can tell the comp height is diff from the two designs but the rods stay the same. cams im looking for a good mid to high end cam, but remember the block i am running is roller.. which also means push rods and rockers will change.. are the rockers the same a sbc? i know i have alot of questions but i am looking for some of the best to pass some info and help.. hopefully it will screem once it starts thanks for all your time and advise..
