i have 88 2.8 tbi and wondering if there's any problems putting a 88-89 camaro 2.8 top end mpfi
top end swap
It will bolt up no problem not sure about hood clearence, if thats an issue. You will have to get wiring harness and computer also, not sure if the distributors are the same. The gain is only 10hp and 10 lb/ft of torque, alot of work for not much gain. The 2.8 can be stroked to 3.1 with a crank and pistons add a cam, headers, porting and a good tune you might have something
Where ever you go.... There you are. (Buckaroo Banzai 1984)
