Originally posted by betterthanyou
View Post
John, sorry, I missed your reference to compression. As for sensors, the 3.4 Camaro engine has the one in the side of the block as I mentioned above, the special front crank pulley with a sesnor bolted to the fromt timing case, and also a cam position sensor at the top of the block, which we remove and plug if we don't want to bother with SFI.
As for distributor ignition, I like the DIS a heck of a lot better (maybe it is having to rebuild my distributor on the Fiero every few years, probably due to the heat near the turbo). In any case, some upper plenums will allow some modification - cutting in to them to clear the distibutor and welding a patch on them, without unduly interfering with flow. I have no idea if you can do this with alloy heads, but I have heard of people doing it with the Camaro 3.4 top plenum shown in my MG cobversion pics. Maybe such a solution might be possible on a 3400 as well?
