I think you may have zeroed this problem situation perfectly!
Everyone has to admire how honest you have been in making this recognition...and in doing so ...you have nailed this problem down tight. You've got Balls as Big as Church Bells, Brother! But to mix and match gears from different Timing Sets ...is antithetical to the very concept that they indeed are exactly THAT...a SET.. with the small gear, large gear and chain all having the same angles of incidence and forming contacts to match each other and transmit and diffuse the forces of torque and minimize friction as much as possible, too. And so they MUST be installed as a complete set. Those are some excellent images you have taken. Thanks for going to so much trouble to improve our understanding. I really hope this is what has happened to explain so much metallic "destruction by dis-agreement (Bruxism)", for lack of a better phrase, to describe what you have discovered. I hope this does the trick and the new hardware going in is better behaved... while still letting you muscle that Pink Machine around with some brand new horse power. If I may suggest one other thing...how about soaking the chain overnight in mixture of Mell-Lube or some other similar quality engine assembly lube... mixed with a can of Valvoline Racing Oil (it has all the metal hardening goodies) or if you prefer...Royal Purple...and this way...you will be giving the new Timing Set the best chance to get off on the right "Tooth"...?
