Originally posted by Superdave
View Post
There is an option for the output on the LM-2 to change the frequency of the update speed. You can slow it down and it will average the readings it takes in between to come up with what it sends to the pcm. I really think the issue here is in the scale range, ie having the voltage range setup on the output to match the range and AFR that the stock narrow band was outputting. Since I couldn't program the outputs on my LM-2 I was having problems. My unit seemed to take a crap on me. It wouldn't update the firmware and then it got stuck on the boot mode screen and wouldn't go off. It's currently back at innovate in CA getting fixed. Waiting to hear back from them.
What I really need is something showing what AFR the mv readings on my stock sensor equals, or at least what the min and max are equal too. Then I could setup my output properly and give it another try. If I can't get it to work maybe I'll try a PLX.
