werent the 94 ecms obd1.5 for the most part?
bad idea?
Pure bolt on so that your ECM has the right reference to go by for the ignition and fueling events. Too bad it is out of stock right now.-60v6's 2nd Jon M.
about the only 1.5 ECMs in 94-95 were the 3100, 3.4iron head, LT1 and i think a 4-cylinder or two... those were the only flash ones IIRC...Originally posted by no_doz View Postwerent the 94 ecms obd1.5 for the most part?
so a 94 3.1 is fine, it should actually be a 16149396....
they got the 3.1, not the 3100...Originally posted by no_doz View Postdidnt the 94 cavalier Z24 have OBD1.5 then?
chart? no, but it would be simple enough to make one. what all do you want to know? ALL FWDs? just 3.1? just 3100?
BTW: you wouldn't find a 5 speed 3100 ANYTHING from the factory. never happened (unfortunately). but swapping a 3100 in place of a 3.1 is easier than swapping a 5 speed in place of a 4t60e.
EDIT: that would actually be a 4t60, apparently only the W's got a -e in 93/94 in 3.1 apps, the others should only be a 3.1/4t60 or 3.1/th125c.Last edited by robertisaar; 10-03-2009, 06:06 PM.
No 3x00 was ever bolted to a 4T60 either, it was always a 4T60E.-Brad-
positive. there might have been 3.1(LH0) 5 speeds in 94, but thats as close as it gets.Originally posted by no_doz View Postvery good info-sad to hear that but are you sure none of the pontiacs came with a 5 speed?
That would have to be one simple as pie swap. I didn't have any problem at all swapping a 284 into the 91 to replace its 3rd blown 4T60-E.Originally posted by robertisaar View Postswapping a 3100 in place of a 3.1 is easier than swapping a 5 speed in place of a 4t60e.-60v6's 2nd Jon M.
so, back to the origonal not so bad idea of the day.
my shopping list would be
1. pair of 3100 or 3400 heads
2. intake from same motor, as well as the injectors, throttle body, coils, wires, etc
3. set of pushrods from???
4. the crank sensor conversion from wot-tech
5. eiring and pcm from???
6. dremel tool to slot some holes
7. gaskets
am i missing anything? what gaskets would i use? is there a thicker head gasket that could knock some compression down?
could someone double check my compression math? depending on which 2.8 i select, i get on the 12;s, or low 13's.
thanks for the helps os far guys. if were sure this will work, ill add the part list to my junkyard bag. that way when i spot something that will work, i can snag it. especially on half price day.
michael
With the 3x00 top end, be SURE you get the metal intake gaskets, not the plastic ones. The extra price is well worth the headache they will save you...-60v6's 2nd Jon M.
