Custom Intake Manifold
I would like to see the plenum and runners from the top without the charger in the way.Originally posted by Superdave View Post
I didn't see what kind of charger is that?
Originally posted by kwhauck View PostI would like to see the plenum and runners from the top without the charger in the way.
Too bad they are too small for a 3.4 cause I could got one for $300 last year. I wish I would got it and put it in my parts hoard.87 3.4 4x4 blazer
all the pictures have the charger mounted, and really the biggest one they offer isn't really that small. Plus it wouldn't be that hard to make a simple adapter plate to move from one charger to the other, or if their is room to have the manifold milled for a different charger opening.Originally posted by neo71665 View Posthttp://www.fageolsuperchargers.com/
Well with a new aftermarket hood design being released for the alero. The design will be changing from a complex custom 2 piece LIM to a stock LIM and very simple box plenum UIM. I have not decided wether or not I will be incorporating a sandwich style W2A intercooler.
lol, Does this mean Hank's gonna need that LIM longer than you thought?Originally posted by kwhauck View PostWell with a new aftermarket hood design being released for the alero. The design will be changing from a complex custom 2 piece LIM to a stock LIM and very simple box plenum UIM. I have not decided wether or not I will be incorporating a sandwich style W2A intercooler.1999 GLS MP90 supercharged / 2003 GL MP62 supercharged / 2004 GLS stock
Subscribed, also probably a dumb question, but I am not quite sure of the flow routing on m90s, on the FWD ones it seems the intake is opposite the pulley, and it pushes air out the square hole, but on the tbird ones it appears that this square hole has to be sealed, with the intake position the same, but the out flow coming out the top/right when looking at one from the front? Am I correct on the flow routing? I am eventually planning to get two tbird m90s....but its hard to try to figure out placement without being positive about the flow routing, oh and I also don't have much of an issue with hood clearance :P
The Tbird M90 is basically flipped upside down as compared to a 3800 M90, with the outlet on top. It still inducts are from the opposite side of the pulleyRIP - 94 GP SE
DD - 95 GP SE
Fun - 91 Mercury Capri XR2 Turbo AWD Conversion
http://www.werbatfik.com
Red represent the outtake that goes to and through the intercooler and into the engine, blue represents the intake where the supercharger draws through air, and the green represents the square that the top piece seals to, but the one on that opposite side that is just an open square that I believe needs to be sealed off?
The area opposite of what is marked in green is not open. The only openings are the green area and the air inlet.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
Huh, could swear I saw several that did, I guess they must have been the GM ones or something, could swear I saw one like that though that had a tbird side exit on it, but hell that makes putting one on even easier, now If I can just find a damn job around here, get me some bigger injectors and an ECM...And I don't suppose you know if that top piece can be flipped the other way so the pipe exits on the other side?
Well since I decided to ditch a custon one piece and move onto a ported LIM and custom UIM..........here is where I am at with a hacked up 3500 UIM. I am now waiting for my heater core/intercooler to show up so I can have the bottom plate machined that will be welded onto this hacked up manifold.
