I wonder how well twin throttles work and what they do to the powerband, I'm guessing they are good for high rpm since a lot of the ferraris seem to use them...Also looks like He took the center plate from a quad 4, I wonder if he adapted the ignition system also(quad 4 has no plug wires, plugs are mounted to that plate)
Custom Intake Manifold
the car uses a coil near plug setup with a 7730, the coils are under the quad 4 cover. the stock intake on a 2.8 is a huge bottleneck, I imagine that improved performance drastically at all rpms.
Edit:
I thought that car was running DIS, but it's not, you can see the distributor under the cover."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
i was kind of wondering about doing a dual intake like this, but was scared to ask.Originally posted by ericjon262 View Postbump, here's a cool custom intake on a iron head 3.4 in a fiero.
[ATTACH=CONFIG]5529[/ATTACH]
the Q4 cover is a neet idea though...
on an iron head motor, I'd be all for it, but I'm not sure there would be enough benefit with it on a gen III motor.Originally posted by bob442 View Posti was kind of wondering about doing a dual intake like this, but was scared to ask.
the Q4 cover is a neet idea though..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
I've thought about dual Tbs as well, would be easier than ITBs, and I plan to twincharge eventually, which makes ITBs a no go. Would love to know how much that intake on the fiero is flowing...or dyno before and after results or 1/4 times or something.
Oh and I'm not saying the stock intakes are good, but they aren't terrible, or the biggest bottleneck, biggest bottle neck is the stock iron heads, also the 3.4 intake on camaros, that intake is a poor design, falls on its face at 5k, 2.8 and 3.1 rwd intakes can go to about 6k with some work to them. But the fwd stuff takes the cake of course....can't wait to hybrid swap, I've decided to put my car on hold atm, it just needs to much crap and I have no job or money atm, going to save up and fix everything at once and build it the way I've been wanting to, between the small cracks I discovered on my intake manifolds and the bad piston rings, I may as well go all out on the thing.....just wish I could find a gd job, going to cost me $2k probably just to get my engine back to good order, and another $1k for the rest of the car.../sigh
And the part I don't get is that it ran great for 2 weeks till the fuel pump died, then the new pump brought it back, but with a terrible idle(but revs fine?) and something loose internally, and a good bit of oil on the plugs, top end is newly rebuilt, but the bottom end has 160k, and of course I discovered the cracks on the intake manifolds when I had to reseal it after the rebuild(overlooked that I had to use RTV as an actual gasket because of the LIM gasket design......Last edited by 2.8/3400 1985 Camaro; 03-03-2011, 12:18 AM.
well, the gen 3's have way better intakes available to them already, for alot less work input, and for me, it's also a looks thing, this looks better to me on a gen 1 than a 3, I just don't think it would look right, I kinda like the "superram" look of the 3500 intake.Originally posted by robertisaar View Posthmm.... why not on a gen3? they can use the extra airflow capabilities better than a gen1 or 2..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
But if it performs, who the FFFF cares
Originally posted by 2.8/3400 1985 Camaro View PostWould love to know how much that intake on the fiero is flowing...or dyno before and after results or 1/4 times or something.
the owner claimed it made a huge improvement, but I don't remember anything measurable.
to this, I dissagee 110%, a 300* bend in an intake manifold like that is never good.Originally posted by 2.8/3400 1985 Camaro View PostOh and I'm not saying the stock intakes are good, but they aren't terrible
Last edited by ericjon262; 03-03-2011, 12:29 AM."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
this is true, but at the same time, if ugly was fast, these would suckOriginally posted by bob442 View PostBut if it performs, who the FFFF cares
http://ratednfornasty.wordpress.com/...-street-racer/
I'ts a 180* bend, not 300....the problem is more the sharpness of it and the small ports, 3x00s make the bend/transition much more smoothlyOriginally posted by ericjon262 View Postthe owner claimed it made a huge improvement, but I don't remember anything measurable.
[ATTACH=CONFIG]5530[/ATTACH]
whoops you're right, I'm using new math...
the 3x00 intakes also eliminate more than half of the runner, have much more plenum, and larger ports."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
did I mention the neck that leads to the plenum is super tiny too?"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
