I've been hanging on to a reground 3.1 crank to build a 3.2 from a 2.8 with but have decided to get a 3.4 PR block and use the crank in it instead. Do I need to use 3.4 rods or 3.1?
3.1 #981 crank in a 3.4
'86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.Tags: None
There is no difference in the crank or rods from any 3.1L/3100 or 3.4L/3400
The only thing that might not be exactly the same would be notches on the timing wheel or not. But if you have the notches your good to go.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
And 3.4 DOHC IIRC.Originally posted by betterthanyou View PostThere is no difference in the crank or rods from any 3.1L/3100 or 3.4L/3400-60v6's 2nd Jon M.
Thanks for the help.'86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
i put a 3.1 crank in a 3400 last night, other than some slight visual differences it worked perfect.
