Next Project... 3x00 or FI ?
  • Next Project... 3x00 or FI ?
    With my firebird now tuneable I'd like to start thinking about the next project for my motor. This is still a year or two off but as some of you know, once I have a project in mind it's only a matter of time and money until it gets accomplished. So that being said please do not take these seemingly vast inquiries as an indication of a lack of research or seriousness on the subjects but rather instead an initial choice that will determine in which path the research lies.
    For those who want a refresh of my car/motor:
    93 3.4 l32 (iron head) v6
    ported heads/intakes, holley adj fpr, 19lb injectors, comp custom cam, all comp valvetrain, cloyes tru double roller timing chain, full intake/exhaust etc. & most importantly (which makes this thread even relevant) 7727 ecm obd-1 swap with $A1 tune.
    I've heard John say many times that once you get tuning in order the other things "fall into place" and I can see why he says that now. The cam/heads setup that I'm running now would not be streetable if it weren't for Ben and his tuning expertise. Or plainly rather, the tune itself. This however has opened up my eyes (and soon to be pockets) to two options left for me to take. I could go the route of a turbo or the route of the infamous 3xoo swap. I'd like to hash out which one will be best for me. But besides that, other considerations are to be kept in mind so I will just go ahead and state them.
    - Which will cost more in the end?
    - Which will produce more power?
    - Which will be easier to tune with my obd-1 computer?
    As far as the tuning goes, I will have to wait for those of you who have obd-1 tuning experience both with the 3xoo swap or with a turbo to chime in because I have no idea how difficult (or easy) either is to tune. I'm assuming the 3xoo would be easier to tune because FI is not involved but that is more of a presumtion than anything.
    As far as power is concerned I realize there are many different "packages" relating to the 3x00 swap and different Turbo's that will vary drastically as far as power is concerned so for the sake of ease let's assume I'm talking about a completely stock 3500 swap ( I don't want to change the pistons as I would likely be doing this work by myself) with a custom cam and full tune, and as far as a turbo is concerned, one of the lower end smaller one's.
    The 3x00 swap I would instally by myself but the turbo I would have to take to a shop to have them customize.
    Let's talk for a second about the 3x00 swap.
    - I would have to go with 3500 heads because I refuse to change pistons.
    - I would need to buy all the parts/adapters available to make the swap simple and straightforward.
    - I would need to buy a custom cam/lifter set.
    - I would like to have the heads cleaned/checked/painted/rebuilt with all necessary valvetrain parts prior to installation
    - I could do all the work myself.
    - I would need to tune this afterwards with my 7727 obd1 computer.
    also, I could sell many of the iron head pieces that I have installed right now to help fund this project since most of them will be useless after the swap.
    Now that seems like a good deal of work but I'm assuming it will be the cheaper option. Plus I enjoy getting my hands dirty (not that i'm very good at it) which is why we do this in the first place eh?
    Now for the turbo...
    - I would have to get one customized at a shop and installed there by them since nobody makes true 3.4 kits.
    - I would have to pay out the ass for this.
    - I would have to install bigger fuel injectors
    - I would have to install a larger fuel pump (walbro 255)
    - I would have to get this thing tuned (I'm assuming we would have to change masks to a turbo based tune?)
    in summary:
    3x00 pros:
    -do the work myself
    -Probably cheaper?
    -I'm assuming not too hard to tune
    - Will really produce some power
    - get to sell lots of old parts to help fund
    3x00 cons:
    - Lots of work...
    - Lots of parts/pieces to buy....
    Turbo Pros:
    - Not much modification on my own part (injectors, fuel pump)
    - Easy to just take to a shop and throw tons of money at it til it turns into a turbo'd beast
    - Who doesn't like that turbo whistle?
    - Engine stays pretty much the same
    Turbo Cons:
    - Cost!
    - I'm sure tuning isn't quite that simple..
    - Turbo would need to be custom
    Will you guys please give me some input here before I really start to dedicate some serious time researching one or the other?
    Even it if it's a one word answer, let me know which route you would go if this were your car, keeping considerations in mind of cost/ease.
    And again I realize lots of my points/questions sound stupid but I'm just trying to figure out which way to go so I can begin my research(savings) in earnest.
    [IMG]http://www.johnlonganecker.com/teamg.jpg[/IMG]
    93 Firebird 3.4
    [FONT="Arial Black"][/FONT][SIZE="3"]Cam and Heads by [URL="60Inclusive.com"]60Inclusive.com[/URL][/SIZE]
    It's so tempting....
    It would be an easy install, tons more power, slight modification required, probably not too costly, tuning would be cake, and I could sell lots of the old parts for monies.
    93 Firebird 3.4
      From what I've read that would be:
      -3500 heads with ls1 springs
      -RWD head gaskets (to match stock pistons)
      - 3500 lower intake
      - 3400 upper intake (with letters shaved for clearance)
      -Injectors (probably 24# would do?)
      - Custom cam & lifters (finally gonna get above .500 lift!, nice and lumpy too...)
      - Custom tune...
      That's certainly the BULK of the parts but i know there is a lot of smaller random pieces needed including things that need to be modified etc.
      I still don't know about the headers, throttlebody (especially the cable aspect), sensors, vacuum hoses etc.
      93 Firebird 3.4
        just found slight modifications:
        - tab on top of timing cover must be cut to allow clearance for the 3500 LIM
        - 3.4 accessory brackets are ALMOST direct fit, just one new hold needs to be drilled center hole drivers side.
        I've already deleted my A/C & compressor & have an idler pulley there.
        Oh one more find:
        - RKsport headers needed, but which ones? Are they actually for the 3x00 head motors? Because i know rk makes headers for the iron head 3.4 .... ( I can sell the old pacesetters...)
        93 Firebird 3.4
          3x00 swap (or top end) would be much cheaper and easier, so I say go for it.
          [CENTER][COLOR=red][B]-Brad-[/B][/COLOR]
          [SIZE=10px][B][COLOR=blue]89 Mustang : Future 60V6 Power[/COLOR][/B][/SIZE]
          [SIZE=10px][COLOR=blue]Follow the build -> [URL]http://www.3x00swap.com/index.php?page=mustang-blog[/URL][/COLOR][/SIZE][/CENTER]
            Brad, it would appear that you and I have come to the same conclusion!
            I would also add that this route seems to be a bit more fun, since it will enable me to get my hands dirty.
            I am now going to start a parts list, along with a list of all other slight modifications and eccentricities. This might be a year or so away, so there should be plenty of time for us to get it all right!
            93 Firebird 3.4
              Why not do both? Get the top swapped and tuned, then add a hair dryer
                lol... I thought they were called snails?
                anyhow you actually bring up an interesting point. Perhaps there are turbo's out there specifically for the 3x00's that would make things easier in the long run going to a turbo??
                I think it's time for a new thread in the 3x00 swap section where I plan on coming up with a parts/modification list.
                Please direct your future attention to that thread.
                thank you!!
                93 Firebird 3.4
                  MAX...
                  There is another practical reason to avoid the turbo HP making angle...aside from the price of fuel...and that is the closer sequence of oil changes required (...is it every 500 ...or 1,000 Miles?) due to the extra compression of fuel/air getting shoved past your rings and contaminating your motor oil.
                    MAX...
                    There is another practical reason to avoid the turbo HP making angle...aside from the price of fuel...and that is the closer sequence of oil changes (is it 500 ...or 1,000 Miles) due to the compression of fuel/air getting past your rings and contaminating your motor oil.
                    No kidding??
                    That is a very short period of time for an oil change.
                    93 Firebird 3.4
                      why shave the letters off the intake when you could just get a venture van intake with no letters at all?
                      [IMG]http://i15.photobucket.com/albums/a351/bob442/monteslowly.jpg[/IMG]
                      Its runs!!!>>>[B]Aint No 60* Sound Like Me[/B][url]http://youtu.be/YKEmNwa141U[/url]:chirp:
                        Cause they are hard to find. Several years ago, I ordered one from GMPD, and they sent me one with the letters....
                          MAX...
                          I've never heard of them being that close together, and I looked at a few turbo cars before I got my 91 years ago. Maybe if you went extreme with the build and boost. If you really do have that much air getting past your rings, you need a rebuild, or fix where you screwed up on your build in the first place.
                          Snails, hair dryers, rotary mufflers, there are all sorts of names for those cool little suckers, er, blowers
                            want some? i'll get you as many as you want
