3.4 egr ?
  • 3.4 egr ?
    I recently installed a 3.4 out of a 96 sillhouette into a 95 gp. car runs great using stock ecm (3.1). The problem is that the egr valve is different, the 96 van engine uses a digital egr while the 95 gp used the old three solenoid egr valve, the mounting pad on the manifold is different and i believe the 3.4 has larger intake ports so i cant swap manifolds. does anyone know how i can make this work?
    by the way , 3.4 is way torquier than old 3.1.
    Easiest thing is to delete the EGR.
      that is the way I am running it right now, how can i do that and not set a code?
        with a HP tuners or EFI live, or just a block off plate and put it off to the side. if not just not unplugging it will run a code, but wont effect anything.
        or this
        [IMG]http://i15.photobucket.com/albums/a351/bob442/monteslowly.jpg[/IMG]
        Its runs!!!>>>[B]Aint No 60* Sound Like Me[/B][url]http://youtu.be/YKEmNwa141U[/url]:chirp:
          or this
          http://wot-tech.com/shop/all/90-95-e...r/prod_75.html
          That egr adaptor would work if he swaps the plenum out for a 00+ plenum, wich would be a good idea!
          I just swapped to a 00+ plenum and made an adaptor to get my egr to work (emissions test was due). I noticed a slight performance increase with the newer plenum, mostly at part throttle.
          1999 Olds Alero 2.4 to 3500 swap (running). totaled by a honda :(
          14.96@91.47 in the 1/4
          9.63@74.36 in the 1/8th
