ok so I just asked about the 3500 crank size... now I have a few questions to ease my confusion before I go buying parts
All build plans will be using my gt3071r turbo and gen 2 ported heads and intake unless noted otherwise w/ manly 3500 valves and a 60mm throttle body. all builds will have Proform billet main caps to help with block twist also SBC rods H-beam(lighter where it needs to be) and JE Pistons. Trans is a Getrag 284 w/ EP LSD
Build #1- 3100 bottom w/ a 3500 crank rod journals modified to accept sbc rods and 3.1 race bearings and stroked to 208ci w/ 3.1L gen 2 heads and intake
Build #2- 3400 bottom with everything else same as Build #1 except journal size on 3500 crank modified to de-stroke crank.. bigger bore of the 3400 to help with deshrouding of valves but destroke to increase rev limit
Build#3- 3500 bottom w/ 3500 crank ground down and de-stroked again to help deshroud the valves, allow use of oil squirters..
Build #4- 3500 motor top and bottom end but w/ a custom plenum and the crank would be de-stroked to allow sbc rods..
Build- # 5+6- oh and after thinking what abouit 3500 heads and lower intake along with the 3500 crank stroked .240 on a 3100?? Is this possible? This would make 208ci on the 3100 bore. or just leaving the stroke the same but still using the 3500 heads and intake and just grinding the rod journals down to accept sbc rods??
question(s)- I noticied a difference in part #'s regarding bearings between the 31xx and 34xx in comparison to a 3500. If the journal size were the same is the 2 other motors the will I be able to use those sealed power H series race bearings?? I didnt know how much the block differed.. On paper it looks do-able.
I have heard that you cannot use Gen 2 3.1 top end intake and heads on a 3500. How much truth is there to this?
Last question for now..- the Turbo Race Cam thats on here http://wot-tech.com/shop/gm-60v6/rac.../prod_275.html
what is the power band like and has anyone used this before?? My machinist after showing him the cam selection liked this cam the most and stated that it should help with lag down low which is better because I have traction issues and pull harder up top. My old 3.1 had an Engle mild turbo cam I can post specs later. max power with my old setup before I changed the downpipe was 309hp and 362tq peak power around 5100rpm. the tune was far from being done but I lost my motor due to a failed oil line
Thanks
-Jarek
Thanks
-Jarek
