Originally posted by SappySE107
View Post
2004 Monte Carlo LS Build (Strictly Performance)
Who knows, that company has a new person porting for them every so often so it is impossible to say with any certainty.
It was in response to him saying a 3100 can't use a 56mm TB because the size isn't big enough. Your 65mm requires the upper to match but yours already does now.
it's the 65mm, i thought you had to have it opened to match the 65mm?Originally posted by SappySE107 View PostYou don't have to swap the upper intake to match the 56mm TB.
MSD coils are hotter and didn't work better than stock on the 3.4 DOHC I own. If hotter coils were awesome, wouldn't I be trying to sell them on WOT-Tech? maybe i should...
and maybe you should? lol jk, since I have them I'll throw them on, if they do nothing I'll sell them, from even what he said, it doesn't seem like it'd be much of a gain, just thought i'd try it since i'm doing wires and plugs too
I did not know this, I'll probably sell them thenOriginally posted by bszopi View PostAll GM coils are the exact same, no matter what engine they came off of.
Originally posted by The_Maniac View PostThe 3400 is more popular I think with the Grand Am (N-Body) folks, you may get more info for performance modding it from them. I think I lot of them basically put on a better exhaust and add a cold air intake. Depending on years of the 3100/3400, it think the the throttle body sizes vary (but to change the T-Body, I think you have to swap the upper intake as well to match). Don't quote me on these, as I have not vest much time on the ideas of modding the 3400.
One thing you can do is swap the coils for those from a late model L67 3800 SuperCharged (these are the ones that have a "blue plug" on the bottom). The 3100/3400/3800 N/A share the same coils (I know from '94 to current '05 and probably a larger range then that). The 3800 SC L67 coils are different, produce a slightly hotter spark. Their is little gain (it's just a slight improvement in throttle response). I am running a set of these coils on my '04 Monte 3800 N/A and my '94 Grand Am with the 3100. I noticed a slight (not huge) change. My opinion, if you swap the coils, total investment should not exceed $20-$30 (again, the gain is very small, so it's not worth paying a huge amount for it). I am running them with stock wires and stock plugs (and as an FYI if I recall, the wires on a 3800 SC and 3800 NA are the same type of wire, just some of the lengths might be different).
And somebody always chimes in to tell me I am wrong and the coils are the same, so before that happens, check the part numbers before telling me I'm wrong, they are different coils.
this is right from monte carlo forumLast edited by trewyn15; 09-30-2011, 04:20 PM.
Stock 3400 coils are enough for 20+ psi boost. You have to gap the plugs accordingly but 40k volts is a lot. I have used Accel coils which are 44k, and they did nothing. I have used the MSD DIS-4 and it did nothing at the track. Better MPG, but at the track, back to back to back it showed no difference in or bypassed. Granted I didn't know how to tune in 99, and sold it before 2001 when I was tuning. It is still an apples to apples comparison with the ignition system. Hell, we used to have an article on this.
from what i heard at Clubgp and Montecarloforum they burn a little hotter and give a little performance, nothing to noticeable, that could be completely wrong tho, are the L32 coils the ones that do that instead or are they all the same still?Originally posted by SappySE107 View PostL67 coils are the same as stock 3400 coils.
With my Monte, I'm going for an all N/A build, it's just a mild build, not getting into heads or cam, yet at least. And try to go without headers first.
Where I started:
What It currently looks like:
Current Performance Mods:
Milzy Tuned PCM, Wizaired CAI (Soon to be painted black):
U-Bend Delete, 18" Resonator into Dual Exhaust:
Poly Motor Mounts to reduce engine rock:
What I currently have waiting to be installed:
TCE 65mm TB:
L67 Coils:
Milzy Motorsports Ported Intake Manifolds/Powder coated Grey:
Magnaflow 2.5" Hi-Flo Stainless Cat.
McCord 2.5" Electric Cutout.
What I'm looking to do:
✓I am currently looking to make a custom downpipe with a McCord Electric Cutout followed by a Highflow Magnaflow cat. (To hold off until I can afford headers)
2.5" Pipe from the Cat all the way back to the Y-Pipe with a 16" Resonator.
I'm also looking to make some 3500 Exhaust Manifolds work to take the full benefit of the downpipe and intake manifolds.
With the L67 coils I'm looking to get red Taylor Wires and new spark plugs (AC Delco Stockers).
Poly Dogbone Mounts to stiffen up the engine some more.
180* T-Stat.
Overkill Tuned PCM or Potentially a Dyno Tune Locally.
Does anyone have any ideas what to add to this? Also any ideas I can do for a little more power?Last edited by trewyn15; 05-01-2012, 04:32 PM.Tags: None
