porting heads...
the real trickhas been finding one with an extended shank most of the ones I have found are short. now there are a few through northern tool and eastwood as superdave pointed out but all of those are for ferrous metals. the only place I have found long reach aluminum cut carbides is here
but I'll have to email them for pricing."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by NateD4 View PostHave you tried McMasterCarr.com or MSC tools They supply a lot of metal working tools to various shops... prices aren't always the best but they usually have it in stock.McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
Thanks, didn't think about McMaster, they have everything!"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
When I ported my heads I learned a trick for consistency. Don't complete each cylinder at a time. Pick a smaller goal like clean valve seat area and do all 6 before moving forward. This helps make it easy to repeat the process for more consistent results.
Also, carbides and sanding rolls wear down. Starting with a fresh tool on cyl1 and end with a dull tool on cyl 6 will create inconsistencies. I used sanding rolls for porting and dedicated 2 rolls per cylinder.
I tried to think across all 6 instead of 1 at a time. When ever I did something, I did it to all 6 whether it was valve seat area or casting flaws. And it is always a great idea to place duct tape over the valve seats themselves. 1 hit and it's over, the seat is flawed.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by TGP37 View PostWhen I ported my heads I learned a trick for consistency. Don't complete each cylinder at a time. Pick a smaller goal like clean valve seat area and do all 6 before moving forward. This helps make it easy to repeat the process for more consistent results.
I tried to think across all 6 instead of 1 at a time. When ever I did something, I did it to all 6 whether it was valve seat area or casting flaws. And it is always a great idea to place duct tape over the valve seats themselves. 1 hit and it's over, the seat is flawed."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
I even went as far as mentally noting how much time I applied the bit per port and tried to keep a consistent pressure. Also faced each port at the same angle, since 2 of 3 face one way I had to reposition my self for the 3rd off set port.
But all that was just background principle. What really made the job for me was running my hands through the area over and over. Knowing each and every little bumb or oddity. Seems our fingers are better at feeling a smooth bend then are eyes are.
Never try to reshape any geometry, only tighten what is already there. Get to know the shape of the ports and fix the rough edges.
Most of your gains will be right behind the valve seat. As that is the smallest spot along the way. Velocity through this area is key and it doesn't take much removal of head material. Since the valve seats are machined to a very nice spec, they can act as reference points. I gently removed the lip and made the port flush with the seat itself. Making sure they are flat to each other as well, no angle. Then gently blend the back side of the grind into the pocket.
This is what I did. I am not a professional like Ben nor did I have a flow bench. But with that in mind, I still was impressed with the results.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
I'm thinking about making a copy rig so I only have to do one port, and then run a stylus over that port to "copy" it."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Not sure what you mean. Many say not to gasket match the heads, no real gains. The most improvement can be made just behind the valve seat. The valve seat itself acts as a guide. And when the factory cuts the valve seat, the back side of the cut has a bad edge on the floor of the pocket. Making the valve seat port flush and blend back will be the ticket. After that, a good texture on the intake pocket. Do not want it too smooth so no mirror polish for intake pocket. But you can and would want to mirror shine the exhaust pocket.
Think, if you had to pump a thick syrup through these heads. My heads, the seams were ugly. I didn't realize how slack the factory casts are.Last edited by TGP37; 03-09-2012, 08:54 PM.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
If it works, good.
I can't see myself using something like that to port heads. Each pocket is different regarding the flaws and the short side radius is hard to reach.
Unless it was used to carve the combustion chamber side like deshrouding valves.
The geometry is already there, it just needs cleaned up. The flaws from factory casting will create a greater level of difference between pockets then a steady hand will.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Dremel Carver/Duplicator Like a Human Powered CNC Router: For the last few years I have seen all these cool CNC projects from affordable rapid-prototyping machines, to laser cutters, to hacked together CNC routers. One of these days when I have the funds, I will build one of these CNC machines but till th…
^ something like that, except set up for five axis."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by ericjon262 View Posthttp://www.instructables.com/id/Drem...-Power-CNC-Ro/
I think a caliper, shop vac and LOTS of light will do much more. I know you can bring each port to a closer spec by hand.
I sculpted many "little" statues and did all sorts of artistic work over the years. Your hands can form precision, it just takes patience and practice.
If you smoke or not, a good cigar hanging in the air helps calm the nerves and steadies the hand.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by TGP37 View PostOne issue is 2 ports are 30 degrees offset from the other. Atleast it is 15 degrees either way for the 3100 aluminum heads exhaust port. And you would need to reverse the movement from the primary. And the pockets are placed where the exhaust valve is outside on both ends. Making linear replication near impossible.
I would do the first port by hand, and then use the pantograph to duplicate it, I haven't figured out how to reverse it yet for the ports that don't line up. It would get used more than once, not just on a set of 3500 heads, I've got some 302 heads, some Lt1 heads, some 305 tune port heads ect..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
