Hey guys, I'm sure a lot of this has been discussed before, so I apologize for anything I might be beating to death.
I'm in the process of restoring / rebuilding my 1987 Pontiac Fiero SE / V6, and I'm at the point where I have to make a decision on the engine.
What I have now is:
2.8 that's undergone a 3.1 crank / rod swap.
- Hypertectic (sp?) pistons w/ .040 overbore
- 1.52:1 roller rockers
- Port / Polish
- 17lb injectors, slight tune.
I ran that motor breifly before I started tearing it down, and it ran "OK" but really took a performance dive as soon as it hit about 4,800 rpms... I mean, hard-core. The car would accelerate quite well, and then it fell off a cliff so to speak. I figured out that it was the cam selection I had, which was predominantly more for a truck. I ended up being a Crane Cam 272, which I was going to put in, but haven't gotten around to it. I only put about 1,000 miles on that motor, and supposedly it had 9.2:1 compression based on what the machine shop (who assembled it) told me.
Now, looking at some threads on Pennocks, I'm entertaining another possibility. As I understand it, I can basically use a 3400 bottom end, and the entire Fiero top-end. This will give me more horsepower, but more important, I'm hoping it'll be a smoother running motor. My 2.8, when stock, ran quite well... really ran like a top, and I'm hoping the 3400 will be even better than that. So here's where my questions are:
1 - What is the difference between a 3400 and an early 3500 block? Can I actually use a 3500 block with the gen-1 heads?
2 - If I do go with a 3400 or 3500, what cam shaft can I use? Only real reason I want to go with a 3400/3500 is for the larger displacement, and the roller-cam. Is there a difference between cam specs on a roller cam vs a flat tappet cam? I'd like to get something that's similar to the h272 in terms of duration, etc, since as I've been told, the larger the duration, the more air it will allow into the combustion chamber... which is better considering the restrictiveness of the Fiero's plenum.
3 - If I go with a 3400/3500, can I still use ALL the stock Fiero stuff, as in, the distributor, the single ignition coil, etc?
4 - Finally... what am I better off doing in terms of reliability, performance, driveability, and fuel economy. Try to re-work my 3.1 conversion motor, or put that on a stand to look pretty, and go with my 3500 idea?
Thanks guys, and just for the record... my goal is really to keep my Fiero looking very original / stock, but improving performance / quality. I'm hoping with the roller cam, the motor will be smoother running, have a nicer smoother sound, etc. I know the Fiero intake will be a huge restriction, but I'm OK with it. I'm not expecting something that'll run 13s... but if I can break into the high 14s with this set-up, and a Getrag, I'll be very happy.
Thanks guys,
Todd
What I have now is:
- Port / Polish
Thanks guys,
Todd
