Originally posted by Xkxbug04
View Post
Looking for some more low end.
interestingly enough, those appear to be 3500 heads in the picture..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Awaiting contact from the seller, glad I posted as I'm 100% new to this motor or Chevys in general. I've just always had straight 6 jeeps. Still have my cherokee with a meaty 4.6l stroker built by myself. They are so extremely simple. This malibu was for the finances daily driver.Originally posted by ericjon262 View Postinterestingly enough, those appear to be 3500 heads in the picture...
3500 heads are better then 3400 heads in stock form, but IIRC, the chambers are too big for the 3100's. the AMC 6 is a tough cookie, dodge did a really dumb thing by doing away with it..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
I'll second that. The one time I didn't go through a good lim leak the cam bearings self destructed because of the coolant in the oil.Originally posted by SappySE107 View PostGet another engine. Im not optimistic about the cam bearings or lifters. You really need to gothrough that motor
Sent from my HTC One X using Tapatalk 2-60v6's 2nd Jon M.
You can always learn to tune the PCM yourself or get a dyno shop to tune your car. That is ONE way to get more power. Considering how far off your tune is, you could get very little to a whole lot more.
If you have the 4t60e trans, an adjustable vacuum modulator thingy can increase line pressure and net you more grab n go from the trans. If you have the 4t65, you need to change PCM settings to achieve the same result.
Then, if you decide to add some more like a cam or cold air intake, you can tune them in to get the most out of it. But do make sure your sensors, engine, etc is up to standard....no failing sensors while tuning.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Same here, my only reference is here.Originally posted by robertisaar View Postnot bad, then again, i don't know what a fresh, stock 3100 will put out.
Just picked up manifold gaskets and oil and antifreeze & distiller water. Gonna get it together and see what happens. If I end up with another milkshake, then ill put it. Apart and grab head gaskets, clean up these heads slightly, shave em .015 to bump the compression a bit and get it back together.
Main concerns for me are that it runs right and gains a bit of mileage. I know I know, 3400 this & that. NO MONEY for that stuff lol.
Any other advice on finishing this up? I've got the pushrods lengths already.
What color thread locker for the bolts? Anyone have a torque sequence & specs please?
Also broke a little plastic quick disconnect type deal. Connects at the thermostat housing and runs backwards. Was curious I if anyone had a part number for it?
