Ok, lets "assume" for a second that the following conditions are true:
1 - Maximum air-flow is not a problem.
2 - Fuel delivery is not a problem.
3 - There is no computer to interfere
I will be using a 2.8 block.
In your guy's opinions... what do I need to do, how do I need to build my engine so that I can achieve a 7k revs, and build power well into the upper rpms. The engine characteristics I woudl like to see is something that's just ridiculously powerful over the entire RPM range. However, I know that's not going to happen, but what I would like to see is something that has decent low-end torque.. it doesn't have to be testicle bursting torque.. but just something that will break the tires loose if it needs to. But I want it to have LOTS of mid-range power, and ALSO be able to produce power above 4,500 rpms. Currently.. in my stock Fiero engine, I'd say that around 4,800 rpms, the engine really starts to let go.. it's an exponential decrease in power. I believe this has a lot to do with the restriction of the intake and throttle body. Since air-flow will no longer be a problem, I'd like to continue to build power at least to 6,500 rpms.
What do I need to do to make sure that I have an engine that's reliable, can withstand those high rpms, and build power to those rpms. What cam would you guys recommend? lifters, rocker arms, pushrods.. cyl head work? What all do you guys recommend?
Thanks,
Thanks,
