i am geting a 84 fiero v6. i want to drop in a 3.4 from a 93-95 camaro. but i want to do a carb conversion. what intake would be best and what carb cfm. milage dosent really mater as long as above 15. witch should be easy in a 2600lb car. also i will be doing a complete stock rebuild of the motor including everything but a few small parts. using a master kit. i will do a full port/polish as well as headers desinged for the car. electric fuel pump. so any intake carb ideas?
fiero swap ideas
all 1984 fiero's were 2.5l iron dukes. either your's has been swapped, or isn't an 84.
there aren't many carb options out there, edlebrock used to make a carb manifold, not sure if they still do..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
There is no way a Fiero with a properly tuned carburetted 3.4L wouldn't get more than 15MPG... unless your pedal is stuck to the floor.
Still available brand new, 2.8L stuff at the top will work on the 3.4L as well...sigpic
- Ben
I don't think it would be easier but it sure would be cheaper. Any S-10 before 86 had a carb so you can grab one from a junkyard. If a FWD car intake layout works better then you can grab on from a car of the same vintage.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Assuming both carbs are rated for 390 cfm, the 4-barrel will be easier to manage in traffic than the 2-barrel. But the 2-barrel will probably be better for racing.
Also, keep in mind the Edelbrock intake will flow better (i.e. better performance) than a stock carb intake.
