I did a search but could find what I was looking for. I want to build a 3.4 rwd block with 3400 fwd heads for a turbo application. I know 3400 or tdc 3400 pistons will give me a lower compression ratio than the 3.4 piston but don't know exactly what the cr would be.
Compression Question
3400 pistons will give you good compression ratio for boost. Will be the same as stock 3400 compression ratio.
IIRC TDC pistons would actually raise the compression ratio more than 3.4 pistons.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
Please don't call the DOHC/Twin Dual Cam a 3400. It is a Gen II motor. Sorry, pet peeve of mine.
Lowest compression would be with the 3400 pistons(28.6cc) at 9.6:1, the 3.4 pistons (8cc) would give you 12.9:1 and finally the DOHC pistons(5 cc) would be up in the 13s...
Looks like there's only one choice if you're going turbo.sigpic
- Ben
