Hi everyone. I have a 2001 Lumina that I'm making a few upgrades to. Are there any 10mm roller tip rockers for these heads? I read somewhere on the forum that they make conversion studs to use the 8mm full roller tips on the 10mm heads. Does anyone know where I can get them?
Roller ip rocker for M10 Heads
I'm not aware of any full roller rockers out there for these engines. Summit does sell screw in studs that can bolt into our heads, but is there a compatible rocker... who knows.Originally posted by TazMan View PostHi everyone. I have a 2001 Lumina that I'm making a few upgrades to. Are there any 10mm roller tip rockers for these heads? I read somewhere on the forum that they make conversion studs to use the 8mm full roller tips on the 10mm heads. Does anyone know where I can get them?"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
You can buy conversion studs for M8 or M10 threaded holes. These will allow you to run Narrow Body Full Roller rockers on your engine. The Crane rockers require LIM clearancing other brands may not. If your not looking for this much work then stick with the stock roller fulcrum rockers.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
