i'm going to be turbocharging the N/A 3.1 MPFI engine in my Cutlass using TGP parts. i'll be changing the head gaskets and installing new head bolts soon. should i use the '91 N/A cylinder heads on the motor right now or should i use TGP heads? is there any difference? i do have a set of TGP heads i can use sitting in my garage. also, i was planning on getting the heads resurfaced....this shouldn't raise compression ratio much/if at all should it?
thanks
thanks
