hey...new here. this is probably a partial repost and i did search and got a few answers but a few questions as well. here goes.
roller rockers first off. Crane Cams Gold Roller Rockers. come in 1.5 and 1.6 ratio. what is my benefit on the 1.6 vs the stock 1.5? i see one guy doing 1.5 on the exhaust side and 1.6 on the intake side...what is the deal there? if i were to go boost over NA which would i be better off with...1.5 or 1.6. and finally i have to do the studs as well obviously but is there anything else that needs to be done?
roller lifters next.
since virtually every GM engine uses the same lifters can i use the hydraulic roller lifters for the 4.3L V6 and if so which set? the 87 to present or the 86 and lower?
if these parts can be used they will be installed on a 2000+ 3400 SFI for an engine swap and turbo setup.
thanks much!
thanks much!
