hey does anyone know if the gen 3 heads can be ported for and fitted with larger valves and if so where such valves would be available
bigger valves
3400 heads have the 1.76 intake valve, but exhaust is still 1.42. Im not sure how to go about fitting bigger valves, but given how close the valve seats are to one another, there's not much room.Robby Whitesell
2006 Pontiac G6 GT
1985 Toyota Pickup DLX
See my post in this thread regarding searching for bigger valves: http://60degreev6.com/index.php?name...424&highlight=
Marty'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
ok heres what ive found out
you can get oversized valves of 1mm larger for both the intake and exhaust
they can be used without any modifications to the head
so thats 1.8 intake and 1.46 exhaust
now im wondering what the result would be in using these size valvesI Like V660s
Does Chevy make beer
~Jayme~
If you don't modify the head by enlarging the throat of the valve seat, or installed larger seats, you won't gain any flow....you will probably end up hurting flow.
Any interference seated or during 5k+ revs?-Brad-
Woah. slow down there trigger.. Your comparing apples to oranges.Originally posted by TheProfessorok heres what ive found out
so thats 1.86 intake and 1.46 exhaust
1.76 is INCH. = 44.704mm, thus 1mm oversized valves(which are made to replace valves that in heads that have worn out valve seats so that the new seat can be cut slightly larger) would equal 45.704mm in orange form which then equates back to the apple form of 1.799 inch, which is just .039 inch larger than stock. get a feeler gauge out and measure this amount.Colin
no interference unless both valves are at .400 inch lift or more at the same time
which should never happen unless there are problems with the valvetrain
colin.....so are you saying that it wouldnt be worth trying out larger valves
and what do you mean apples and orangesI Like V660s
~Jayme~
intake valves are 1.76inch. you posted 1mm oversized valves =1.86 inch i was simply pointing out you were confusing two different forms of measurement and getting them all jumbled around. 1mm oversized equals the number you now edited your post to as i pointed out..Originally posted by TheProfessorno interference unless both valves are at .400 inch lift or more at the same time
and what do you mean apples and orangesColin
where did you find thisOriginally posted by smilinguy99Here's a link that shows just how much room there is to put bigger valves in a GenIII head:
http://www.novia.net/~sparks/heads/GEN3_HEAD_PARTS.html
anyway to contact themI Like V660s
~Jayme~
