doing a 3400 swap into a miata.
things would be greatly simplified by using the RWD timing cover and water pump. I was GIVEN a 2.8 Camaro engine that has a carb on it. all the accessories and everything.
since this is a GRM Challenge build ($2018 to build the entire car, must be documented), id like to use what I have on hand.
near as I can tell, theres no boss for the crank position sensor cast into the cover. I didn't expect there to be, to be honest. engine is not in front of me yet, as it gets delivered next week.
I'm wondering if anyone has a picture of how the crank sensor mounts and reads the front of the crank. cant seem to find a picture online.
even better would be if someone has modified the early cover to accept the CPS. I don't mind some TIG and fab work.
other question is whether it will line up with the FWD cast oil pan.
so, ideas/experience/interchange info?
