Well a blower would sure give him the type of power he wants, but at a cost. Tuning it will not be fun, and it sounds as if he doesn't want to tune. This ITB can be run off of his stock ECU, fuel, and ignition setup. Not a good idea, but it would work. For a blower, you need to change the entire engine setup. For best results, drop compression, new ECU or piggy backing your current one, fuel delivery improvements across the board, etc.
I'd use a larger TB for the blower, that 3.1 TB would just make the blower starve.
Plus, running the TBs cross style, or any way other than pointing up, it will not be too dificult to keep it under the hood. As for IAC, that is easy. Out of each TB/carb you run a line, all to a common box, your vacuum box. To this runs all of your vacuum accessories, and your IAC basically just bypasses, and lets outside filtered air into the box. Plus you still have screws to adjust the idle manually on 99% of TBs and carbs. It seems a lot more complex and difficult than it actually is.
