Hey everyone. I just pulled a 3100/4T60E out of a 93 Cutlass for one of my projects. I have the complete engine and transaxle, the underhood wiring harness, and the computer. I didn't pull the harness from inside the car, but I did get the gauges, plug, and about a foot of its harness to wire them up.
Question One
Do I have everything I need for this puppy to run properly?
Question Two
Is there a diagnostic port somewhere in the Cutlass? Should I grab it too, or is it the same as the one on the Fiero chassis it's going in? If you're wondeirng why I don't just look for it, the car was once inhabited by stray cats and it makes me itch just thinking about going in there.
I want the swap to be as clean as possible, so here's what I have done so far/plan to do: I fabbed an idler pulley from the a/c compressor pulley to replace the power steering pump. I am in the process of fabricating mounts to move the alternator down to where the a/c compressor was on the left side. I removed the coil pack (will be mounted on the car) and am reworking the harness to clean things up.
After I get it set up right and swapped in, I plan to extract more performance from it. I will try to share some pics soon, and have more questions...
Question One
Question Two
