their 1.6:1 roller rocker kit comes with their metric/sae conversion studs.
i thought i read somewhere (or understood/misunderstood) that they are adjustable rocker studs. if they are considering the things i have done with my 3.1/3400 hybrid build would it be possible to reuse pushrods, and get the right amount of preload? with the correct geometry?
i have read how to find the preload on cranes site and understand it but am not sure if they were adjustable. i didnt see anything on there about torque to yeild lol
a lil exerpt from the reading on the site.
"To adjust preload on hydraulic lifter camshafts with
adjustable rocker arms, turn the engine in the normal direction
of rotation until the exhaust lifter starts to move up, then
adjust the intake valve to zero lash with no preload, then 1/2
to 1 turn more. Turn the engine over again until the intake
opens completely and then is almost all the way back down.
Now, set the exhaust valve to zero lash, then 1/2 to 1 turn
more. Continue the above procedure for each cylinder until
all valves are adjusted to the same amount of preload. This
procedure will give you the correct lifter preload for any
hydraulic lifter cam with adjustable rocker arms."
-crane cams
-from a post by aaron
"You just have to install the old length ones first and check the geometry to make sure the roller tip on the rocker stay in the middle 1/3 section of the vavle stem."
he also mentioned ONLY using the gen 2 pushrods because they are heat treated (apperently) for using with the guideplates, which i also have to use.
is that the correct way to check the geometry? i have taken .02 off the heads , have a reground camshaft from a stock 3.1, obviously going to get the rockers
i think i have a handle on this, but thanks for anyone who can shed more light on this
regards,
brad
-crane cams
regards,
brad
