will a TB from a new 99+ grand am work on my 96 grand am
TB ?
Just take the shaft from the 96 3100 and swap it to the 3400 TB.
To do this, take off the TPS, undo the torx screws in the throttle plate, turn the plate sideways and pull it out. Then using a hammer, tap on the TPS end of the shaft, and it'll come out. Watch a couple of things when doing this. First, don't let the spring come loose and smack your hands.....IT HURTS!
Next, there's a small ring on the end of the shaft that locks it in place....don't loose it when tapping out the shaft.
Good luck!Franz
1990 Z24-NA 3.1L
14.72 @ 92.24 MPH
14.89 @ 94.92 MPH
The boost is coming....
